Idle
Old Jan 4, 2004 | 01:18 PM
Vinson581's Avatar
Default Idle
how can i set the idle on a 87 lt230 quadsport, it seems the carb wont close all the way.
Old Jan 4, 2004 | 04:40 PM
hondabuster's Avatar
Default Idle
The cable should adjust, to give the thottle some slack, so it can close all the way. Is the slide return spring, in tha carb binding or installed wrong? Is the slide in the bore, dirty or tight?
Otherwise check the idle mixture screw, for proper adjustment, or the enrichener(choke) may not be shutting totally off or float hieght, could cause that.
Old Jan 4, 2004 | 05:54 PM
Vinson581's Avatar
Default Idle
yea thanks, the thing is stuck at like 1/4 throttle, i do not want to shift= instant wheelie.
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
