Dead '98 Quadrunner 500
Old Nov 29, 1999 | 03:10 PM
MarkCollins's Avatar
Help.I have just 69 miles on my quad and it died after simply leaving it parked outside for 1 week. I have a spark & fuel to the plug but it won't start. The battery is fine but not even a sputter. Any thoughts before I haul it to get fixed. THANKS
Old Nov 29, 1999 | 07:53 PM
quad500's Avatar
Is there gas going completely thru the carb...sounds like u may have dirt in the jet or if u live in a cold climate, it may have produced condensation in the carb and froze up...
Old Nov 29, 1999 | 08:28 PM
Tree Farmer's Avatar
Condensation in the fuel system; water in the float bowl could produce the symptoms mentioned.
Assuming your kill switch is in "run" (you said you had spark), I'd make sure the carb had dry fuel--dump or drain the float bowl, drain the tank through the reserve petcock, put in fresh gas, and give it a try. Maybe give it a shot of starting fluid through the carb, maybe dump some gas treatment in the tank to take care of any residual moisture.
Good luck!
Tree Farmer
Old Nov 29, 1999 | 08:56 PM
r34's Avatar
r34
You might want to check that the fuel valve is at the ON and not the PRI position. This PRIME allows fuel to flow directly into the carb, and can easily overflow and run into the engine.
Old Dec 13, 1999 | 04:28 PM
Thanks for taking time to help me out. I took the quad inside, drained carb bowl to make sure gas was coming in (yes), and tried some quick start. Still won't start. I'll try to drain the tank and refill but I thought if it were a fuel problem I'd get something with the quick start.
pgamboa
Dec 24, 2023 11:52 AM
Dammar
Apr 20, 2016 06:03 AM
phummer3210
Sep 11, 2015 03:47 PM
DM2015
Sep 7, 2015 10:36 AM
Sep 1, 2015 11:59 PM
