LT250R reeds??
Old Jan 11, 2004 | 08:20 PM
newLTkid's Avatar
Default LT250R reeds??
i just got my 1990 LT250r back together after having it completely rebuilt and when i rev it the RPMs stay high for a couple of seconds and then it will finally get back to the idle. are my reeds just wearing and staying open?
Old Jan 11, 2004 | 09:12 PM
LT250RSuperstar's Avatar
This might sound weird but I think you have an air leak....or maybe your idle set screw is in just a tad too far.
I wish I had your quad cause I can't find a Laegers LT anywhere......Your Skylers friend right?
later
Superstar
Old Jan 11, 2004 | 11:14 PM
newLTkid's Avatar
where would an air leak be? i'm glad i have my quad. the reason you are having trouble finding one is because there were only 3 ever made.
Old Jan 12, 2004 | 12:28 AM
NichelsonRacing87's Avatar
my LT is doing the same exact thing and i put new reeds in it thinking that was the problem but it wasn't and i also had the carb cleaned out with acid by a professional. my dad told me it is extra air entering with the already mix fuel/air.
Old Jan 12, 2004 | 01:21 AM
Some of these can be possibilities... could be a bad intake flange....bad base gasket.....bad crank seals, but since you had it redone you can count out the gasket and seals.....hmmm
later
Superstar
Old Jan 12, 2004 | 07:56 AM
tom18801's Avatar
well just get her running at a idle and spray starting fluid in large amounts all over any gaskets and all around where the carb is clamped to the intake and if the engine suddenly revs where you just sprayed you have an air leak.
Old Jan 12, 2004 | 12:49 PM
I forgot about that test...I do that one myself too....
Old Jan 12, 2004 | 02:16 PM
newLTkid's Avatar
i haven't heard of that test. i'll try it later today. i came home for lunch[img]i/expressions/face-icon-small-smile.gif[/img]
what should i do if i have an air leak? would i just need a gasket?
thanks
LTkid
Old Jan 12, 2004 | 03:42 PM
Bubba297's Avatar
Yeah, if it's around a gasket, then either replace it or tighten it down a little (dont laugh, it happens[img]i/expressions/face-icon-small-smile.gif[/img]) Dont forget about the carburetor top coming loose. That could create an air leak also that would do the same thing.Bubba
Old Jan 12, 2004 | 05:47 PM
newLTkid's Avatar
alright, i tried the starting fluid test and it didn't rev when i did that. does that tell anybody anything?
