After torqueing bolt I can't get the cotter pin hole lined up?
Old Jan 18, 2004 | 09:22 PM
JOEYG's Avatar
Default After torqueing bolt I can't get the cotter pin hole lined up?
If I torque the bolt that holds the hub on my 03 Z400 quad I can't get the cotter pin in because teh hole is not lined up with the nut correctly, what can I do?
Old Jan 18, 2004 | 11:51 PM
LT250Rodney's Avatar
Tighten the nut good and tight, then back it off till a hole alligns with it. As long as the pin is the right size even if it does loosen a bit, it won't allow the nut to slack off to the point the hub gets wobbly.
Ozark38's Avatar
It will be alright to either + or - to line up with a hole............mmmK?
pgamboa
Dec 24, 2023 11:52 AM
Steeldon
Sep 9, 2015 09:38 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
