K&N filter oil on foam...
Old Jan 23, 2004 | 05:23 PM
GTFZ250's Avatar
Default K&N filter oil on foam...
Can I use the filter oil on my stock foam filter? It is in a spray aerosol can if that helps.
Old Jan 23, 2004 | 05:38 PM
Quadfather's Avatar
I suppose you could. The directions say not to. I don't know if the world would come to an end, or if you'd be hurled back in time, but I just wouldn't do it.
I would use some heavy weight motor oil before I'd use K&N oil on a foam filter, if I was in a pinch.
Old Jan 23, 2004 | 05:58 PM
WISTECH's Avatar
Dont do it. K&n oil is made to stick to cotton gause filter and if sprayed on foam it will run to the bottom of the filter a drain into the airbox or worse down the carb. Use foam air filter oil or engine oil ,anything but that crap.
Old Jan 26, 2004 | 11:51 PM
steinster's Avatar
use the right oil for your foam oil filter it will save you a mess later ok take care [img]i/expressions/face-icon-small-smile.gif[/img]
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
