trottle limiter screw on Z250
I Unscrewed it a little bit is this going to force the motor to run unsafely or would the Suzuki people have thought that some might unscrew it and set it below the motors full potential to play it safe?
In other words am I going to F***anything up by unscrewing it???
I messed with the screw on mine and didnt notice any difference at all. I don't think unscrewing it will do anything. But screwing it in will limit the amount that you can open the throttle.
well think about it: the more throttle you give it, the higher it will rev. If you unscrew the limiter screw, it will allow you to give it a little more throttle, then it will be able to rev higher and go faster. You can take it off, but it doesnt matter cause it will automatically stop anyway when it runs out of room but i left mine on a little bit so its as open as it can get, just so no dirt gets in the hole where the screw was. But i did notice a difference
Oct 10, 2015 10:20 AM
