quadracer starting problems
Old Jan 25, 2004 | 09:19 PM
STLbanshee's Avatar
Default quadracer starting problems
The big is a 87 and the problem is when its cold out, or the bike has been sitting for a while it will not start with out being pop started, but after we finaly get it started from pulling it, the bike will start fine the rest of the day. We have checked for air leaks, and cant find any. Its a 87 with a 38mm carb, a paul turner high rev pipe, a pro design head and I think 19cc domes.
Old Jan 25, 2004 | 09:38 PM
StlZuk's Avatar
Im the owner and its actually a 36mm carb 22cc dome coolhead
Old Jan 26, 2004 | 12:04 AM
crblick's Avatar
The next time you let it sit for a while, before even trying to start it, check and see if there's a build-up of gas in the cylinder. Check it first before you touch anything or move it. Try getting a reed kit for it, that made my old Honda 250R I use to have start a lot easier. If you do have excess gas in the cylinder then you prolly know what's wrong.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
