quadzilla
Old Jan 30, 2004 | 12:32 AM
anthony7's Avatar
Default quadzilla
i need some advice. my zilla has no spark. the plug is good. compresion is at 135 is this ok. i think the base gasket is blowed or partly blown. what is the correct compresion for a zilla and what to check first for a spark. you allways have to roll it off till it is warm then it fires. we rode it for 20 min and it was ok. then we tried to roll it off and it would only hit once in a 50yd pull and now no spark at all. help.
Old Jan 30, 2004 | 12:37 AM
RodSmith32's Avatar
Default quadzilla
you could have a weak spark. Even though you test for it the spark may not be hot enough to fire the engine, I would test the cap for proper spark. I know it sounds stupid but have you tried a new plug, I had a similar problem that a new plug solved.
Old Jan 30, 2004 | 12:44 AM
anthony7's Avatar
Default quadzilla
new plug did not work. stick a screwdriver in there and it will not bite you. still searching.
Old Jan 30, 2004 | 10:06 AM
minnrider's Avatar
Default quadzilla
do you have an ohm meter anthony?if you do you can check the ohm values of the stator and the cdi box to aid in tracking down the problem.i dont remember the exact ohms.i could run down to the shed and get them sometime.........too cold here now..-20......brrrr[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jan 30, 2004 | 11:42 AM
Duneaddict's Avatar
Default quadzilla
If you think the base gasket is blown... DO NOT RUN IT!
You need to buy/build a leak-down tester and test it for leaks, and repair any you find BEFORE running the motor...
Then you can troubleshoot your electrical issues.
Leaky base gasket=lean condition=kaboom!! You'll have alot more issues than just weak spark at that point!
My $.02
Old Jan 30, 2004 | 12:01 PM
UKzilla's Avatar
Default quadzilla
i usualy test my spark by putting something metal in the cap and letting the misses hold it[img]i/expressions/face-icon-small-wink.gif[/img]
works everytime,LOL
works on the motherinlaw as well,,
Old Jan 30, 2004 | 12:43 PM
minnrider's Avatar
Default quadzilla
LMAO.....uk [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 30, 2004 | 01:20 PM
UKzilla's Avatar
Default quadzilla
i know its funny but i realy do it, my excuse for not holding it my self is that i cant hold it and kick at the same time.LOL
Old Feb 1, 2004 | 07:26 PM
CTATV's Avatar
Default quadzilla
Need your stator rewound? Ricky stator comes to mind. Wouldnt not having a spark posibly be corolated to a stator that isnt creating electricity for the spark?
Old Feb 15, 2004 | 09:05 PM
ZukZilla550's Avatar
Default quadzilla
UKzilla you crack me up LMAO!!
