Stripped nuts Help!!!
Old Feb 4, 2004 | 03:29 PM
Lt250rKid's Avatar
Default Stripped nuts Help!!!
I have a bunch of nuts on my 86 lt250r that are stripped and i cant get them off and i need to get them off so i can get the frame powder coated. Does anyone know how i can get them off or have any ideas?
Thanks,
Alan
1986 Lt250R Quadracer
Old Feb 4, 2004 | 03:30 PM
BigBadScrambler's Avatar
Craftsman has a stripped nut and bolt remover kit. Other than that, you will have to grind them off, then drill them out and re-tap or helicoil them
Old Feb 4, 2004 | 03:35 PM
Lt250rKid's Avatar
what would i use to grind them off?
Old Feb 4, 2004 | 03:44 PM
A die grinder or angle grinder. Is it the nut that is stripped, or a bolt? Cuz if it is a nut, you may be able to cut it off. The best way (if you have a lot of them) is to invest in the Craftsman Bolt-Out™ Damaged Bolt/Nut Remover Set
Old Feb 4, 2004 | 10:19 PM
MBrooks420's Avatar
A nutsplitter is always handy. Looks like a small c clamp with a wedge on one side. You actually cut the nut right off. Grinding them out isn't horrible, but should be last tried thing. Soak them with penetrating oil for a while. PB blaster is fairly good. The best things I have found for rounded nuts and bolts is a good set of channel locks.
Old Feb 4, 2004 | 10:30 PM
JustinJones's Avatar
weld another nut onto the stripped nut and then use the new nut to remove the old nut. works for me. easy, too.
Old Feb 4, 2004 | 11:35 PM
SuzukiZ250Kid's Avatar
Yeah, welding a nut on there is probably the best way if you have a welder. I don't know how good the Craftsman nut and bolt remover is, but their screw remover SUCKS. Also if there is enough of the head left, you could try locking a pair of vise-grips on it.
Old Feb 4, 2004 | 11:47 PM
Marky522's Avatar
I dont know how to explain the tool, but if you have enough room to comfortably get a wrench on the bolt then there are a special wrench, it is for stripped bolts the end is closed and as you pull tighter it pushes this rounded piece of the handle into the nut , which in turn loosens it, i hope someone on here can make sence of this... lol
Good luck, oh yeah a new set of quality vice grips works better than a old set...
Mark
Old Feb 5, 2004 | 01:13 AM
broke's Avatar
Where are the stripped nuts located? If you got space a small pipe wrench works great. welding nuts to the existing ones works great also, also if you can borrow a torch setup heating them up cherry they get on they they should come right off, as long as you wont damage anything by heating them up.
Old Feb 5, 2004 | 01:34 AM
ragtag's Avatar
Try vise grips. And, lots of penetrating oil.
