quad nuts bolts set
Old Feb 9, 2004 | 12:52 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default quad nuts bolts set
Mark
the ebay bolt set is fine if you are a conscience quad rider
only a few bolts will be in a high stress situation, with torque specs well below their capability
pre-trip your bike as usual, and see how the bolts do
I havnt had a problem yet
certain bolts require more attention than others,,,,just pre-trip accordingly
if they are installed properly with loctite,,,,,you should be golden
Old Feb 9, 2004 | 09:18 AM
ZigZilla's Avatar
The stainless steel bolts sets are fine. Plus they look trick as is......if you take them to a buffing wheel before installing them they look like chrome. Good luck.
Old Feb 9, 2004 | 10:56 AM
sam250's Avatar
Some of the clutch cover and stator bolts broke when I tried to remove them because they were rusted in place. All the strength they had was of no use when they rusted because they were made of plain steel. They were also phillips head which is much more likely to strip than the allen head on the stainless ones. The set that I got was only for the clutch, stator, water pump, and sprocket covers. I think it had case bolts as well. I replaced the motor mount bolts with new ones from suzuki. Those are cad plated and won't rust.
Frisky2050
Apr 9, 2020 11:19 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
