LT125 Brake Drum--Help!
Old Jan 15, 2000 | 12:24 PM
Wannabee's Avatar
Can't get the brake drum off the shaft on my '86 LT125. Shoes are free, axle spins free. I think splines are frozen. I've tried using a slide hammer puller, penetrating oil and propane heat with no luck. Tried removing the chain sprocket and pounding axle out thru the drum and axle housing but it won't budge. Am afraid heating with an oxy torch might warp drum.
Any better ideas?
Old Jan 15, 2000 | 02:58 PM
THEXOTIC1's Avatar
get a gear puller that will fit the drum i had a lt185 that did the same thing
Old Jan 15, 2000 | 03:45 PM
Wannabee's Avatar
Thexotic1--How bout a hint where you found such a gear puller. Only ones I've found with long enough arms have jaws too large to fit in the drum holes.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
Sep 1, 2015 11:59 PM
