Water Pump - 87-92 quadracer help.
Old Feb 18, 2004 | 02:04 AM
thesb's Avatar
Default Water Pump - 87-92 quadracer help.
Does anyone know if you have to split the cases to install the water pump oil seal and mechanical seal? I haven't got it apart enough yet to look and I don't know if I should order gaskets yet.
Old Feb 18, 2004 | 08:31 AM
greenbud's Avatar
what's up
no juat take the clutch side cover off and there it is.... you may need that gasket (clutch cover) to complete the job. also make sure that the bearing on the shaft spins free with out problems.. hope this helps
later
Old Feb 18, 2004 | 04:13 PM
donzilla's Avatar
NOTICE !!!!! the bolt holding the impeller on is left handed threads . so take it off clockwise .
Old Feb 18, 2004 | 07:48 PM
ZukZilla550's Avatar
Hey DonZilla, did you get your footpeg's yet?Your quad rock's.....BLING-BLING.
Old Feb 18, 2004 | 07:52 PM
donzilla's Avatar
yep i sure did . i havent had a chance to update my pics yet . but i will very soon . [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 18, 2004 | 07:54 PM
Cool I made mine years ago and they sure look good shinning in the sun,can't wait to see the pic's.
Old Feb 18, 2004 | 07:58 PM
thesb's Avatar
Thanks for the help guys. I hope the oil seal is the only problem. I was getting a lot of coolant in my gear box. Are there any other seals that the water/oil could come through?
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
