suzuki not starting need help quick
Old Feb 23, 2004 | 08:40 PM
2phast4u's Avatar
Default suzuki not starting need help quick
i got bought an 1986 suzuki 230 well it was a 230 but the guy that i bought it from just got bigger pistons in it and now its not starting its a kick start its its fairly cold its about 25degrees do u think its not starting because its to cold or what please give me reasons why it may not b starting the gas is fun chokes s on fuel is on key is in sooo what do u think is wrong?
Old Feb 23, 2004 | 09:29 PM
lt250rthriller's Avatar
u should probably check the sparkplug and see if that is fouled if not ask the guy if the piston is too big
Old Feb 23, 2004 | 10:17 PM
mudrover's Avatar
I have an 87 and its just hard to start it aint the cold and it aint your spark if its like mine. Are you using the compression release if you do its almost impossible to start with out it being 75 degrees if your big enough kick it hard with out the compression realease but if your like me and not pull it behind a car goin like 10 shift to 5th and dump the clutch it will start everytime like that.
Old Feb 23, 2004 | 10:18 PM
chickenhead's Avatar
CHECK TO SEE IF YOU GOT SPARK BY PULLING YOUR SPARK PLUG OUT PUT ON THE WIRE AND GROUND IT TO THE CYLINDER AND KICK IT OVER IF YOU GOT SPARK CHECK COMPRESSION WITH A GUAGE... GOOD LUCK
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 27, 2015 08:07 AM
