Steering Stem
Old Feb 26, 2004 | 12:21 PM
quadracer239's Avatar
Default Steering Stem
I have a 86 lt250r, i have alot of up an down play in my steering stem what do i need to do?
Old Feb 26, 2004 | 12:46 PM
ZigZilla's Avatar
Straight up and down???? or back and forth??? For straight up and down , you might want to try shims(such as thin washers) to remove the play. For back and forth play you will have to replace the bushing.
Old Feb 26, 2004 | 12:50 PM
sam250's Avatar
Make sure all the washers and seals are installed correctly and the nut on the end of the steering stem is tight. If you don't have a shop manual you can see a parts diagram here.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
