lt230s specs?
Old Mar 20, 2004 | 11:18 PM
Vinson581's Avatar
Default lt230s specs?
230 has 5.8 in the rear, and 5.3 in the frount i belive is what i was told at one point when i had mine.
wheelies on that 230 were my speaciality, i could ride them to 5th gear at like 45-50mph. word to wise-dont sit on grab bar in 1st and punch gas-you might get scared, it points to the sky, best way to wheelie them is a first to second shift, and then keep he up.
Old Mar 21, 2004 | 11:28 AM
MBrooks420's Avatar
Actually they have 5.9 inches of travel in the front and 7.9 in the back.
Other specs are
Overall Length 73.2in
Overall width 41.7
Overall hieght 43.9Wheelbase 44.9
Ground clearance 4.9
Front track 31.9
Rear track 30.6
Dry weight LT230E model ONLY 373lbs-quadsports would be about 30 lbs lighter
Turning radius 8.2 ft
Old Mar 21, 2004 | 12:07 PM
MalHombre's Avatar
i read in a Suzuki brochure that the '85 Lt230S only weighs 309# dry.
Old Mar 21, 2004 | 12:11 PM
MBrooks420's Avatar
I don't see how they could wieght that much less. The only wieght savings are battery, starter, auto clutch, and aluminum rims.
Old Mar 21, 2004 | 06:10 PM
  #15
Vinson581's Avatar
hey mbrooks you have to get some pictures up there man.
Old Mar 21, 2004 | 06:18 PM
  #16
mudrover's Avatar
first day i had my 230 i figured id pull a little wheelie in first ( I don't have a grab bar[img]i/expressions/face-icon-small-shocked.gif[/img] ) on black top to impress my cousin so i reved it up a little and dropped the clutch and stood the thing straight up i went home and changed my pants!!!Just kiding. But yeah they are wheelie machines also does any one know how much it would cost to replace swingarm bearings, my shop told me 475$$[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 21, 2004 | 06:20 PM
  #17
MBrooks420's Avatar
I've been holding off until the weather gets a little better. I replaced all bushings/bearing, rebuilt the carb and threw on a K&N so it was rideable, but it needs some more work. It apparently never had any maintence by the second owner. I have a new gripper seat cover, and have been considering some powdercoating for the wheels, frame,ect. I need some new tie rod ends real bad. Oh, and to replace the knuckle arm bolts I broke off last time I went riding. [img]i/expressions/face-icon-small-shocked.gif[/img] 4 miles home with one wheel flapping in the breeze.
Old Mar 21, 2004 | 06:22 PM
  #18
MBrooks420's Avatar
Get yourself a full chassis bearing kit off of e bay. Then do them yourself. It's not very hard. Worst case scenerio is you end up taking the swingarm itself to ANOTHER reputable repair shop, and having them do it for a lot less. You could buy a brand new one for much less, with new carrier.
Old Mar 21, 2004 | 06:47 PM
  #19
MalHombre's Avatar
yeah, i got a bearing set on ebay for under $50. i had a local shop press the swingarm bearings in for $10.
Mbrooks, i'm just repeating what i read in the brochure. once i get mine running i'm gonna get it weighed just outa curiousity.
Old Mar 21, 2004 | 08:01 PM
  #20
MBrooks420's Avatar
With light modificatons and equal riders a 230 will outrun a 300ex.
