how to know if theres enough oil??????????????????????????
Old Jul 14, 2000 | 01:08 AM
iwana400ex's Avatar
how do you know how much oil is in the side case on a 1991 suzuki lt250r???????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ???????????????????// what kind is the best?????????????????????????????????????????????? ????????????what is the ratio for gas/oil mix??????????????????????????????????????????????? ????????i just bought this quad dont know to much about it......................
Old Jul 14, 2000 | 11:49 AM
THEXOTIC1's Avatar
On one of the sides of the cases you will see a small bolt or phillips screw. after filling up the crank case take this screw out you should see a little bit of oil come out. Thsi will tell u that it is full. I would reccommend That you pick up a Ratio Rite cup for $5. This way you can measure the correct cc of oil and pour it in. I have an LT500 and use Bel ray 85W. I also change it after 4 days of ridin. $4 for 1 liter or $1000 for transmission work. You deceide
