Neutral and Reverse Light
Old Mar 20, 2004 | 10:46 AM
SuzukiKingQuad300's Avatar
Default Neutral and Reverse Light
I own a Suzuki King Quad 300 and for some reason the neutral light and reverse light will not come on. If the neutral light does not come on i can not use electric start. I have checked the fuses and they are fine. What could be the problem??
Old Mar 20, 2004 | 06:55 PM
AlaskaBoy's Avatar
Have you messed with the linkage on the reverse lever? Sounds like it to me. AlaskaBoy.
Old Mar 20, 2004 | 08:09 PM
LT249r's Avatar
what year? I agree with alaskaboy, it could just be your linkage cable on your reverse lever, you should also check to see if its connected to the brakes!!! Good luck
86 LT250r
Renthal chains and sprockets
Works Performance front and rear nitros shocks
Boyesen power reeds
answer exhaust
Port and polish
nerf bars
Old Mar 20, 2004 | 08:14 PM
AlaskaBoy's Avatar
SuzukiKingQuad300, I forgot to welcome you to the forum. So here it is "Welcome aboard".
I have noticed that there are not many King Quad guys on here, but the ones that are very helpful. I used to own a 95 but I was allowed to upgrade( the wife gave me the checkbook[img]i/expressions/face-icon-small-happy.gif[/img]) so I jumped ship. AlaskaBoy.
Old Mar 21, 2004 | 12:11 PM
Thanx for the advice. The four wheeler is a '99. A dealer thought it might be a little switch under neath the air box, But the thing is so hard to get off i have not checked yet.
Old Mar 21, 2004 | 02:29 PM
eiger2's Avatar
Welcome to the forum! Its good to hear from another Zuk owner.
Prolly a switch problem.
Old Jan 9, 2011 | 02:42 PM
bink 65's Avatar
Originally Posted by suzukikingquad300
i own a suzuki king quad 300 and for some reason the neutral light and reverse light will not come on. If the neutral light does not come on i can not use electric start. I have checked the fuses and they are fine. What could be the problem??
2001
Old Jan 9, 2011 | 02:43 PM
bink 65's Avatar
no didn.t touch
Old Jan 30, 2018 | 12:50 AM
Buck Mccovey's Avatar
Hi all I have the same problem going on where my neutral light and reverse won't light up and my quad won't start I tracked wires and cleaned all places where they disconnect and still nothing pls help
Old Mar 29, 2020 | 08:56 AM
Rob Cartwright's Avatar
Default Reverse. Neutral
I just replaced wire harness from 95 suzuki 300 kingquad of course with a 1996 harness ..but the harness has a 3 wire plug to the reverse neutral plug and my old was had a 2 wire plug ..when I test for power from the new one I get power from 2 of the 3 wires but very dim and need a y are they dim ..everything else thru out harness is bright and do I need that third wire if I switch back to the old plug..please help!
AdirondackGal
Jan 27, 2015 06:47 PM
yourhero
May 18, 2013 07:04 PM
dh9318
Nov 2, 2008 09:07 AM
