quadracer questions
Old Mar 20, 2004 | 12:59 PM
needaR's Avatar
Default quadracer questions
-how many hours do you usually get inbetween rebuilds on these?
-will the 87 reed cage fit the 89's?
-how much does a common top end rebuild cost? and a bottom end?
-are there any companys that make wider aftermarket a-arms?
thanks.
Old Mar 20, 2004 | 01:03 PM
waynaferd's Avatar
250 or 500?
Old Mar 20, 2004 | 01:07 PM
needaR's Avatar
oh sorry,250
Old Mar 20, 2004 | 04:34 PM
needaR's Avatar
sombody has to know
Old Mar 20, 2004 | 05:18 PM
Chromezilla's Avatar
I have a 500 and cant belive there would be much of a diff. between the two.
Usally about 1 season, about 100-150 hours I replace my rings. You can get about two maybe three ring changed out of a cyclender if yer nice to it. 100 to 150 hours is actually a lot more then you think. You may go riding for 3-4 hours but you engine time is prob. only about 2 hours with smoke, bs breaks and so on. I got a trail tech spedo from Rocky Mount, and was amazed how much time I acutally screwed around more then rode, any hoot
I have no idea about the cage diff. I know 500 where diff.
rings=20-30 bucks
piston and rings about 80
hone job 80-100
bore 120-150
lonestar and Laeger still love the quadracers and I am sure they still make + a arms for her.
ca
Old Mar 20, 2004 | 05:38 PM
bgdog's Avatar
the reed on a 87 are difrent than the 88-90
Old Mar 20, 2004 | 06:02 PM
needaR's Avatar
thanks guys.i didnt think it was that much hours in between rebuilds.i was thinkin 50-60.thats cool.
heres a dumb question but do lt250r's have keys?do they have anything besides an on/off switch or do you just kick and go?
Old Mar 20, 2004 | 07:28 PM
ToppNotch's Avatar
85/86 quadracers dont.. 87+ do i believe do have keys. i have a 86 and it had no key
Old Mar 20, 2004 | 07:38 PM
Slacker1bob's Avatar
Chromezilla goes to an expensive machine shop.
I did an entire rebuid for $200
$100 for piston, $60 for bore and hone, and $40 for gaskets and top end bearing.
How often you do it depends on your riding habits. I wouldnt mess with ring jobs, when your compression starts dropping off, then do a top end job. Once every 3-4 years should be fine. It takes me that long to put 150 hours on. If you top end is on its original bore, you can get 4 more bores out of it, so even if you do it every two years, your good for 8 years.
Old Mar 20, 2004 | 08:25 PM
Cali and NY prices over here. I am in Cali now, and those damn tree hugging Squirrel saving s-o-b's have killed all fun out here.I cant even find a chrome shop out here!!!!!!!!!!!!!!!!!!! .;-(
ca
