which carb for 89 lt250r?
a 36mmPJ or 35mmPWK? .20over,FMF pipe uni silencer,uni filter,no air box lid.will it help as much as as people hype about?i prolly will have the head shaved a little and some port and polish work in the future but i dont want to run too rich right now.should i just wait?
Are those what you have available to use, or are going to get. If you already have them, then it is a tough choice. I really like the PWK. If you are going to get a carb, try to get a 36 or 38 pwk.
How does the 38 pwk fit on the intake side boot is it hard to get on? The intake side on a 38pwk measures 46mm I'm running a 34 PJ right now that measures 41 mm and it a tight fit on stock boot w/boysen rad cage. Also will the 38PWK Airstriker work well or do you need alot of p&p work to run I want to go bigger with a new carb but dont want to over kill.
Thanks
Thanks
If you are going to Port and Polish your motor in the future dont screw around with those little carbs get a Keihn 39mm PWK and be done with it 38 PWKs are good too PJ's are junk
MIKUNIS ARE JUNK they bog if you do any type of racing like for instance MX or SX it cant take the whoops and big jumps you could use a PC RACING carb vent system but that only works a little.
ANY MORE QUESTIONS LET ME NO
MY QUAD IS FOR SALE over $8,000 invested
FIRST $4,500 takes it home
87 Qracer
Ohlins Front Shocks w/rezzies
metallic blue frame
Kawi Green Swingarm and steering stem with other green parts
Burgard +2 a arms
DuraBlue Axle 2+2
K&N Filter TRX250R style LOTS OF FLOW
Kenda Klaw tires
Grooved Radial fronts
DG NERFS
AC BUMPER AND GRAB BAR
DID CHAIN
PORTED AND POLISHED
HEAD SHAVED .010
190 psi compression
DG PIPE/SCILENCER
Dark Blue Maier Plastic
85 Seat w/new cover
MOOSE HANDLEBARS
BARNETT CLUTCH
TONS OF EXTRAS TO MUCH TO LIFT
87 Qracer
metallic blue frame
Burgard +2 a arms
DuraBlue Axle 2+2
Kenda Klaw tires
DG NERFS
DID CHAIN
PORTED AND POLISHED
HEAD SHAVED .010
190 psi compression
DG PIPE/SCILENCER
85 Seat w/new cover
MOOSE HANDLEBARS
BARNETT CLUTCH
VERY VERY FAST
ALL SET UP FOR RACING
email me @ c_borning@hotmail.com
or call me at 507-828-1233
first 4500 takes it home WILL NEGOTIATE
90 % OF THESE PARTS ARE BRAND NEW
