high octane
Old Mar 26, 2004 | 07:35 PM
tb400guy's Avatar
Default high octane
can you run high octane in your z 250 will you have to change any thing in the carb will it make a differance in the prefromance at all
Old Mar 26, 2004 | 08:04 PM
waynaferd's Avatar
Default high octane
No, its only good for high compression ratios to help with detonation. You won't notice a performance difference.
Old Mar 26, 2004 | 09:57 PM
Doctorturbo's Avatar
GOT BOOST!
Default high octane
You can if you want.
NO, not unless your running an oxygen based race fuel. Then you will have to richen it up.
Mmmmmmm, depends. Again, if you run a high octane, oxygen race fuel; well yes, you will if you tune it right. Thats a hard question, but, yes, it will make more power if tuned right. If your talking about dumping in some octane booster and leaving everything stock, no you won't make more power, and could loose some.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
