Brake Pads
[img]i/expressions/face-icon-small-smile.gif[/img] YOUR PROBLEM IS PROBALLY BECAUSE THE CALIPER PLATE THAT MOUNTS ON YOUR SWING ARM HAS TWO PINS THAT ALLOW YOUR CALIPER TO MOVE BACK AND FORWARD AS YOU APPLY BRAKE IF THESE PIN GET STUCK (IN WHICH THEY DO ALL THE TIME) IT WILL CAUSE YOUR PROBLEM SO CHECK THE PINS GOOD LUCK
oliveiracarlos
Sep 7, 2015 03:39 AM
