01 King Quad need help!!
I know the brakes are a big issue with the king quads... but I have replaced mine on the back for the 2nd time but never getting a good braking. You have to stand on the foot pedal to get the tires to slide and using the hand lever is worthless. Its like you put grease in the drum...or something.
Thanks Scott
Thanks Scott
Drum brakes and so-so seals, one of the flaws of the old KQ design. You *should* be able to clean out the brakes or replace the pads and get decent braking - at least until some mud & water seeps in, but it's very possible that grit and mud in the brakes have worn your drum down. I had this with my '94 KQ, IIRC, the rear drum was about $250 just for the part.
Here's hoping the new KQ is all discs.
Jaybee
Jaybee
I have replaced the brake pads and cleaned everthing and put it back together. The drum was fine...as far as having a good pedal i do..just like new... but no stopping power. Like the going from power steering to none.
I gave up on the rear brakes and just replaced the front shoes. I, yes I admit it, paid the dealer one time to do it thinking that it would be like new. Ha, the brakes had to be readjusted within a few miles and before the trip was over they was toast. I even asked the dealer why the hand lever felt so mushy and he said it was the best they could do. Never again will I ever allow Suzuki to touch my quad, could be because I sold it , but that is beside the point. I found the shoes with the grooves in them to work the best, for the front that is.
Did you adjust it by the foot pedal? How about pulling the arm off the and taking some of the slack out of it, not much but will make the brakes lock up alittle faster. AlaskaBoy.
I have a 2001 king quad and i havent had no trobule with the brakes the only problem i had is when i drive sideways on a small hill it flips over.
2002 yamaha grizzly 660 has hmf pipe, jets, k&N air filter, bear claw tires
2002 yamaha raptor 660 with ct racing exhaust system and jet kit and k&n air filter, ct racing pistons , Top-End Gasket, CT Aluminum Air Box, dg front bumper
1999 250 bear tracker with fmf megamax pipe
2001 suzuki king quad 300, winch, floorboards
2 1999 polaris sportsman 335 (sold)
IM planning on getting a 2004 suzuki Z-400
Frisky2050
Apr 9, 2020 11:19 AM
