440... ..how does that work
Old Apr 19, 2004 | 01:10 PM
Blaster2fast's Avatar
Default 440... ..how does that work
if i have everything but the 440 jug/sleeve ie pipe cams piston rev box carb blah blah... what exaclty would a 440 do for me? just up the cc to 40? how can that be so much more powerful if its only 40 cc's?
Old Apr 19, 2004 | 01:16 PM
yamahawarriormods's Avatar
yes it will only give you another 40cc put along with the piston you will get you will notice a good size difference
Old Apr 19, 2004 | 06:47 PM
LT250Rodney's Avatar
There is no replacement for displacement. It's as simple as that.
Old Apr 19, 2004 | 06:52 PM
craZ400's Avatar
Look at the power difference between the z400 and yfz450 which is actually a 440. The yfz is nearly double. Don't ask why, just know that it does.
Old Apr 19, 2004 | 08:41 PM
KFXCarnage's Avatar
They make a 470cc kit for the z/kfx/dvx now.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 19, 2004 | 11:50 PM
If im not mistaken someone makes a 500 kit for the Z400.
Old Apr 20, 2004 | 03:02 AM
craZ400's Avatar
I know duncan makes a nice 470, but who makes the 500? How much and what does it come with?
Old Apr 20, 2004 | 08:40 AM
z838mx's Avatar
guys just the piston doesent make much difference you have to make it breath also to get alot of power increase you need to put cams and carb on it also. then you need to step up witn an ignition. just putting a piston in the machine is hardly worth it. kfxcarnage call ct the 440 kit still puts out the most power of the big bores and is the most expensive of the kits just for your knoledge. The 470 kit is a torqe monster but it doesent rev out as well so the is your difference. the 450 yoshi kit is pretty impressive but anything more then that your losing to much in the side of the cylender. I checked with everyone when I did mine and talked to alot of people and found that the 440 was the best. also remeber hight compresion will also aid to your performance but then you may have to run racing fuel.
Old Apr 20, 2004 | 02:48 PM
jaycekarl10's Avatar
Good news, the guys at Crower racing are currently working on building CNC machine ported heads in combination with a new cam and highr comp piston (no boring or stroking necessary) that should be able to put the 450's in their place. Currently the project has undergone stage 1 on the porting process with a 12:1 piston, custom cam grind and a 38mm Lectron on race gas.
During the last test there was only a 400cc Alcolol drag Banshee it couldn't catch.....other 400 & 450's weren't close. That's the target, to surpass the cammed and piped YFZ 450 without even getting into the whole boring and re-nicking the jug.
Any questions, I'll try to answer as the process continues, but their hope is to offer a kit that will be much less than the current 440+ kits.
Old Apr 21, 2004 | 03:03 AM
BINGO!! THAT IS EXACTLY WHAT I WAS LOOKING FOR!
