adjusting chain
Old Apr 19, 2004 | 07:24 PM
sportnquad's Avatar
Default adjusting chain
how do you adjust the chain on my 1988 suzuki quadsport? I have the clymer repair manual but it
doesn't show the setup i have.
thanks
Old Apr 20, 2004 | 01:54 PM
zman420's Avatar
if its the same as on my '89 lt250s you have to loosen the two large bolts that hold the axle carrier to the swingarm and then tighten in the two small (12mm) bolts that are below the axle carrier, if those smaller bolts are all the way in you need to take a link out of the chain. make shure you tighten those smaller bolts evenly then get those larger bolts TIGHT
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
