Pull start from hell
Old Apr 26, 2004 | 09:22 PM
patchrick843's Avatar
Default Pull start from hell
i was just wondering if there was any way at all to put an electric start or a kick start on a pull start suzuki lt 185 because i cant take it in the cold weather and i end up puting alot of starting fluid in it and i dont want to ruin the quad it runs great once started if anyone could help please reply
Old Apr 26, 2004 | 09:59 PM
aksafari's Avatar
I had an ATV70 three wheeler when I was a kid in Alaska, and unless it was below 0 F outside, it would start pretty easily. If you have to use starting fluid every time, then you are probably having choke problems or float level problems. I'd check to see that your choke butterfly is closing all the way, you might do a compression test, too. If that engine has a decompression system, then check the adjustment on it, as well. If it's pulling open too far (if you even have one) then your compression will be too low to start easily.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
