kill switch on lt250r...
Old Apr 30, 2004 | 12:56 PM
scottymack's Avatar
Default kill switch on lt250r...
hey guys, I have had some problems with my quad and have most taken care of with the help of the forum. I have been towed for miles after breaking down thinking something was wrong and finally figured out that I have a bad run/stop switch. Wish I would've figured this one out sooner, could have saved alot of time. Anyway I heard this is a common problem and was wondering if anyone has put aftermarket kill switches on the lt250r. I would like one that I could still use my headlight. Any input would help...thanks
Old May 1, 2004 | 03:28 AM
LT250RSuperstar's Avatar
Hi there, I got a Prodesign killswitch on mine...um I took off lights though, BUT you should still be able to set the wiring up so you can use a toggle switch or something to do your on/off...don't know about your High/low though...
Hope this helps ya bud
later
Superstar
Old May 2, 2004 | 08:09 PM
LT2Fiddy's Avatar
for your lights...you might be able to hook up a 3 way toggle switch...where its off in the center...and low on the bottom and high on the top...dont know if it would work though.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
