zilla clutch options
i would watch out for the kevlar plates they can raise havoc with the fingers on the clutch basket. If You have the money i would look into a the hinson clutch basket also it drops the leverage about half and just makes it a lot smotther feeling. Barnett Dirt diggers good brand see if you can get it without the kevlar.. check rocky mountian they have some cheaper units i thinks its primary drive like 60$? Ebc has a good kit also but its a little over 100$
03 HP 300
88 lt 500r
91 Lt250r
03 HP 300
88 lt 500r
91 Lt250r
Ok, I found one of the statements, Its not saying that the Billet units are that bad, but states a few drawbacks, again, I didn't write this, Dr Q did:
posted 04-16-2003 05:29 PM04-16-2003 05:29 PM
Clutch: The stock clutch/hub/basket plates work pretty well w/just a HD (Barnett/EBC) spring change.(These motors have so much torque you hardly ever need to fan the clutch) If the basket fingers and hub get grooved from the steel plates the clutch action will be poor. Also, the clutch drive gear springs get fatigued/loose after a while. This makes for a noisy clutch as well as transmits more of a "shock" load thru all the motor on engagement.
Warning: Those "bitchin" aftermarket billet clutch baskets have a couple of huge drawbacks.
They require reusing your old drive gear off the old "junk" basket you are replacing. Unless you had a "freak" failure the old drive gear springs will be loose. This not only causes the above "shock loading" but also "works" the bolts they give you to install it on the new basket until they oval out the holes in the gear hub and let the gear/basket assy get loose. Now EVERYTHING that rotates w/the clutch is subject to excessive vibration and runout DAMAGE.
The billet basket is a quality piece as long as you attach to a new/good drive gear correctly.
Otherwise, by a new OE Suzuki basket/hub/plate.
$.02 more
I have a few more that recommend the stock clutch with heavy springs, Ill keep looking
$.02 more
Also, from what I understand this applies only to Zillas, as they have not been graced with the aftermarket R&D that Banshees and 250Rs have. Im sure a better setup COULD be invented, but how profatable would it be? There are many choices for the Shees and Hondas, and since the market is more dense, this forces more quality.
I found another article, Ill keep looking till I find the other 2, then Ill post them
