lt250 with 38mm airstryker
Old May 3, 2004 | 12:55 PM
1987LT250's Avatar
Default lt250 with 38mm airstryker
hi anyone have a 38mm airstryker on their lt 250 if so what mods and main are u using this thing starting to irritate me lol i need to make sure im in ball park ty shon
Old May 3, 2004 | 07:14 PM
800screws's Avatar
i'm in the same boat with the jetting. i haven't put it together to try it, but i live in new york and heard 182 to 178 is a good ball park to start in. what are u at now?
Old May 3, 2004 | 10:04 PM
1987LT250's Avatar
i ran 160 and was running lean so jumped way up to 180 and it ran beatiful but the problem was i only needed half throttle to reach wide open any farther made it choke on the gas so i stepped down to 175 nd its seeme better on take off through 3rd but 4th 5th and 6ixth act as if im bogging at full throtle fine at half throttle
let me know if ya got any ideas im stock bore 38mm air stryker fmf gold series fatty pipe boysen reds and rad vlave no lid on airbox im gonna get a kand n filter and remove the airbox i dont think i getting enuff air wish i could get this done so i can start moding suspension next oh yeah i tryed comparing with a 1990 same setup but he has the small intake port and rad valve seeings i have the 87 with the bigget intake so who knows lol ( not me if worse comes worse ill put the 180 back in her and use it that way i was getting used to it and plug seems to be choclate caramel in color
Old May 4, 2004 | 07:31 AM
800screws's Avatar
hmmm....that could be it too. u are running it on a stock motor. i have a ported cylinder, radvalve.
Old May 4, 2004 | 08:27 AM
1987LT250's Avatar
i had a pwk 38mm on it running good so i cant see the stock motor fresh topend bothering it but ive been wrong before lol
Old May 4, 2004 | 09:24 PM
1987LT250's Avatar
ok guys gimmie a lil help common now lmao are airstrykers junk lmfao or rarely used all these lts and no help wahhhh hahhhhh lol will appreciate any advice at this point lol
Old May 4, 2004 | 09:32 PM
800screws's Avatar
if it is running good, then what's the problem??
Old May 4, 2004 | 10:18 PM
1987LT250's Avatar
its running great and caramel plug but it only takeshalf the twist throttle to reach wide open and if you go ny farther it chugs til u back it back off to wide open (being half throttle)
Old May 5, 2004 | 02:09 PM
Tankota's Avatar
I'm gonna bump this to the top cause I'm also interested in the answer. I've also got the same carb on mine but I haven't run it yet and the previous owner said it probably needed to be jetted.
Old May 5, 2004 | 02:50 PM
CapnMorgan's Avatar
Your too rich on the main. you should only change jet sizes 1-2#s at a time. I would try a #168 main and mess with the clip position on the needle.
Hope this helps.
P.S. Unless you ride in the same area and have the same mods it doesn't help to compare to other peoples jettings.
