great idea! but will it work?
Old Jul 29, 2000 | 12:15 AM
QuadDude05's Avatar
i just had some wierd idea pop into my head so i shot over here to see what everybody thought. i was thinking, LT250r a-arms on an lt230? or maybe some other type of longer a-arms on it? i know it's popular with honda's and stuff, j/w if u think it's possible? like if u had any measurments or sumpthin
Old Jul 29, 2000 | 11:35 AM
86Honda200SX's Avatar
That would be a good idea,but I don't know anybody that owns a 250 to measure them.
Old Aug 2, 2000 | 02:02 PM
krb1184's Avatar
That sounds like a good idea, if it will work. I have an '86 LT 250R.If you tell me what measurements will you need, I can go check for you.
Old Aug 2, 2000 | 04:34 PM
If you don't mind measue the width of the top and lower a arms.Also the length,width,heigth of the bushings.
Old Aug 3, 2000 | 02:01 AM
krb1184's Avatar
The upper A-arm is 10 1/8 inches wide. The lower A-arm is 9 3/4 inches wide. It is 2 1/8 inches wide from bushing to bushing at all four places where the A-arms bolt on. Each bushing is 1/4 inch wide. Hope this helps.
Old Aug 4, 2000 | 09:07 PM
ecorman1's Avatar
Sorry Quaddude but you're not making any sense. Not to **** you off but the measurements you're asking for will only be as good as the person doing the measuring. People do measure differently. Take the tubing for the A-arm for instance. To measure the distance from the front tube to the back tube, do you measure from center to center, outside to outside, outside to inside or inside to inside? It really doesn't matter if you know what you want as the end result. The problem lies in how the information is interpreted by the second party. In this case, that's you.
Why don't you try something a little simpler? Go down to your nearby dealer with a tape measure, paper and pencil. Draw what you want, check deminsions against the equipment on the dealer's floor, draw your witness and deminsion lines there, so you know what you did. That's going to make you more confident with the information you're getting. Did that help any? Hope so...
Chuck, Suzuki KQ 300, GPS & lunch...
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Hondapolaris8596
Jul 9, 2015 12:53 PM
WilliamBos
Jun 11, 2015 05:57 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Rob
Sep 28, 1999 07:21 PM
