exaust valve
Old May 23, 2004 | 07:33 PM
wickedlt's Avatar
Default exaust valve
saturday did some much needed minor maintainence on my 88 lts50r.
New reeds, muffler packing, air filter, alot of cleaning, and odds and ends.
Two things stumped me,
1. I took off hte pipe so i could spray carb cleaner inand free up the power valve, felt pretty gritty, but i got it moving by hand, could see the linkage in the sight glass, once reassembled and fired up, revved it out, no movement in the glass, and on the other side the setting **** is kinda frozen up, i put a pliars on, didnt wana break it so next week ill look at that. My question is, adjusting **** holding things up, or is it probably soo gunked the cylinder needs to come off?
2. I wanted to polish some stuff like my rims and pipe, bought the pads, the bar clay polish, and went for it, what am i doing wrong, ive seen mirror like results on aluminium, i couldnt even get a minor change? what gives?
3. I put in dual stage boyeson reeds, live in chicago, (for those concerend with altitude) without getting too technical, is rejetting in my future?
my magic 8 ball said "a possibility", so i need some better advice
Thanks guys, always appreciate your help
Old May 23, 2004 | 08:25 PM
1987LT250's Avatar
on your power valve take the 2 crews outta cap and pull it out . clean the cap then lub it with little oil should spin freely while in place without the screws tightened. then put the spring back in it line up groove in cap with spring. now take it and spin it 360 degrees counter clock wise ,put screws in tighten them your done. now pull the window and be sure the linkage is connected . good luck
Old May 23, 2004 | 09:25 PM
Doctorturbo's Avatar
GOT BOOST!
What color polish did you get? Black is the most harsh, white is the least harsh. Dark red and I think brown are in between.
Also, what pads did you get? Denim and sisal are the harshest and cotton is the least harsh. If the metal is cast, it is best to debur it with sandpaper. Don't be afraid to get down on it. Aluminum will get so hot you will need gloves.
Old May 24, 2004 | 09:37 PM
waynaferd's Avatar
Really oxidized aluminum needs to be sanded down before you can buff it. I had my cylinder off and I removed the power valve to clean it......it was really gunky!!
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
