Carbs. For Z-400?
Old May 24, 2004 | 02:30 AM
MURDR's Avatar
Default Carbs. For Z-400?
I heard the z-400 carberator is highly restritive and to put a 38mm edlebrock carb on it and will crank. Does any one know if this is true? Also some had told that even if you were to put the 400ex carb on it u would still gain 1hp.
Old May 24, 2004 | 02:39 AM
scrambler123's Avatar
I doubt the thing about the 400ex carb. I do know from experience however that a 40fcr gives good gains you can get one here for cheaper than enywhere else just look for it on the crf450 parts.
Old May 24, 2004 | 03:03 AM
Blaster2fast's Avatar
i am running a FCR39...works nice
Old May 24, 2004 | 11:35 AM
rolsmojave3's Avatar
you can put on an accelerator pump
Old May 24, 2004 | 12:30 PM
Ball's Avatar
Put an accelerator pump on the stock or on the aftermarket?
Old May 24, 2004 | 01:16 PM
MURDR's Avatar
Does a new carb give alot of power or what? Is it worth the money?
Old May 24, 2004 | 02:18 PM
1Fast03z's Avatar
if ur gonna mod the engine past cams and exhaust its a must! without those still gives u some good gains
Old May 24, 2004 | 03:04 PM
Lolli2's Avatar
The stock carb has an accelerator pump on it. You should try airbox mods and rejetting the stock carbs before you wanna drop the $400 on a new carb.
thrshr
May 2, 2002 07:37 PM
QuadsportKid
Apr 20, 2002 06:21 PM
Toaster
Mar 8, 2002 12:17 AM
Toaster
Feb 15, 2002 12:52 AM
