how do i adjust valves on my vinson and eiger
I am about to adjust my valves back to factory specs...eiger is making a clicking sound and vinson is slight click...anyways I was wondering if anyone knew how to find top dead center on the compression stroke...is there a plug on the crankcase for it??
thanks
-MJE-
thanks
-MJE-
Right above your pull start there is a plug with about a 50 hex head. Pull it out and take the pull rope assembley off. I think it is a 14 mm to turn the motor over. There will be a white mark in the hole that is either tdc or tdc compression stroke. Feel your valves to find when they are loose when the mark is up and it will be tdc compression stroke. If you need the valve adjustments, let me know.
i have the valve specs on the 2002 eiger...i need them for my vinson to make sure..
what i have so far for the vinson is .05 - .1 MM intake...and .17 - .22MM exhaust
thanks a million man thats what i suspected was the thing i needed to take off however i couldnt find a hex head for that size.
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
