Realter tires
Old Jun 1, 2004 | 08:53 PM
ElectricShift's Avatar
Default Realter tires
Does the Z250 have enough power to spin a pair of realters over, and are they hard on the grass?
Old Jun 1, 2004 | 08:58 PM
Also how about 20in fast Trekkers? Will they drop my ground clearance too much?
Old Jun 1, 2004 | 11:59 PM
2StrOkeFReaK's Avatar
Are you riding in alot of sand? If not tale a look at Hole Shot XCR. They are a sknnier than the realtors and wont rob any hp. They allow you to control your slide big time through the corners. Execellant on wet clay/grass, the treads clean themselves very well. Not real hard on the grass either. They are not for you if you run on pavement
at all !! they shread up.
My .02
Old Jun 2, 2004 | 04:16 PM
TomM's Avatar
The 20" Fast Trekkers are actually 18.5". On my LT250 they are about as hard on grass as a rototiller. They get great traction but when they do break loose they put a lot of the ground in the air.
Old Jun 2, 2004 | 06:54 PM
92Racer's Avatar
I would think with the bottom grunt of a four stroke that you could do well with those tires. I have had them on my Racer for a few years. They really grab. Not to great for sliding around. They will tear up the grass some. Plus they are a big tire so they do rob some power, but I tell you what those tires will get you out off a hole that you would normally think that you couldn't touch. I took them off two seasons ago to try a set of bandits. The bandits you can slide and I like doing that. I did notice that the traction was not nearly as good as the realtor when it came to mud and sand. Now a 500 has no problem sliding the Realtors, but that is another topic.
Old Jun 3, 2004 | 12:18 AM
mahnster's Avatar
92racer- How do you like your PT engine? Shes gotta be one b!tchin ride!
Old Jun 3, 2004 | 02:58 AM
92Racer's Avatar
It's pretty sweet.[img]i/expressions/face-icon-small-happy.gif[/img] I really like to hear it when ever I can.
Old Jun 3, 2004 | 03:30 PM
Thanks guys, I thought about turf tamers, but they look like they would clog up easily, and I ride in lots of clay.
Old Jun 3, 2004 | 06:07 PM
Lots of clay, look at XCR's. They flat hook up, wet or dry!!
I have a set on both of my R's
Old Jun 3, 2004 | 10:36 PM
mahnster's Avatar
Razr's would be good too.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
