Z400 Question?
Old Jun 2, 2004 | 12:22 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default Z400 Question?
Do you have to adjust the valves after break in on these, wasn't sure.
Old Jun 2, 2004 | 01:07 PM
zman420's Avatar
I've heard you don't have to, but the dealer may tell you different $$
I've talked to a few people who have checked the valves after over a year of ridden and the valves are right on. i'm not going to worrey about the valves on my new Z, but just change the oil for the break-in. Im still not shure what oil to use, synthetic, syn-blend or straight 10w-40?
Old Jun 2, 2004 | 04:42 PM
FsT4WrD's Avatar
I have used the Valvoline atv oil, never adjusted the valves. Now after a year my quad is in the garage tor down cause I have to do a valve job.
Check'em, adjust them, and use a good synthetic oil (Amsoil or Henson) If you blow it off and use cheap like I did then you will have to be with out a quad and do it your self or be charged 300 bucks to fix the problems that can be caused.
Oh ya, just replaced the clutch yesterday cause it was cooked from useing the cheap oil.
Old Jun 2, 2004 | 05:11 PM
zman420's Avatar
Dang that sucks, how hard/often do you ride your quad?
I use the Amsoil full-syn 0w-40 in my other quad, never have had any problems, actually just took the clutch apart for the heck of it, put it all back together, no new parts needed!!
Did you adjust the valves at the break-in service on your KFX?
Old Jun 2, 2004 | 05:57 PM
FsT4WrD's Avatar
Ride about 50 to 80 desert miles almost everyweekend, most of the time it is in 4th and 5th pinned. Yesterday was the first time I have ever checked the valves, I only checked them cause it sounds like a disel
Old Jun 2, 2004 | 08:48 PM
KFXCarnage's Avatar
I havent messed with mine yet but its not that old eather.I run Amsoil too.
How can you tell if the valves need adjustment?Sound?Feel?
Old Jun 2, 2004 | 09:06 PM
brutis's Avatar
My dealer told me you dont unless it starts to have an irradical idle.
Old Jun 2, 2004 | 10:26 PM
z838mx's Avatar
dot do it until you hear them ticking and making noise. It doesent take to long to do them and I have done it two times on my z you can tell when it needs it.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
