Spark Plugs???????
Old Jun 3, 2004 | 01:26 PM
GTFZ250's Avatar
Default Spark Plugs???????
what is the difference between the NGK DR7EA, DR8EA AND DR9EA? What do the numbers mean?
Old Jun 3, 2004 | 01:37 PM
1987LT250's Avatar
lower the number hotter the plug
2 hot of plug not good
Old Jun 3, 2004 | 01:53 PM
GTFZ250's Avatar
should I try to run the coldest plug possible without fouling?
Old Jun 3, 2004 | 04:57 PM
CHEWBACCA's Avatar
just get another stock plug. They're DRZ250
Old Jun 5, 2004 | 12:39 AM
GTFZ250's Avatar
Are u joking about the DRZ250 thing. That is a dirt bike not a spark plug. The choice I have according to the manufacturer are what I posted up above.
Old Jun 5, 2004 | 03:33 AM
hondabuster's Avatar
Id put whatever the owners manual says to put in . The hotter plugs are kind of a band aid for worn motors, which burn alot of oil. If the stock plug fowls out, then the jetting needs to be adjusted.
if you want to know more about plugs, read this article.
spark plugs
Old Sep 18, 2005 | 10:34 AM
naturalite's Avatar
I was reading this thread and come upon some thing from the NGK website. It was interesting to me, I didn't know that there was a diffrence between manufactures.
from the NGK web site
The heat range numbers used by spark plug manufacturers are not universal, by that we mean, a 10 heat range in Champion is not the same as a 10 heat range in NGK nor the same in Autolite. Some manufacturers numbering systems are opposite the other, for domestic manufacturers (Champion, Autolite, Splitfire), the higher the number, the hotter the plug. For Japanese manufacturers (NGK, Denso), the higher the number, the colder the plug.
Old Sep 18, 2005 | 10:51 AM
garrett5462's Avatar
lol[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 19, 2005 | 12:11 AM
mucky's Avatar
stay with the stock plug unless you have had motor work done
Old Sep 19, 2005 | 06:20 PM
yup, if you start screwing around with spark plus, befor you know it there will be a hole burnt in your piston...
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
