LT250r Trans. Oil
Old Jun 21, 2004 | 07:35 AM
800screws's Avatar
Default LT250r Trans. Oil
yup, local dealer should have it
Old Jun 21, 2004 | 10:47 AM
GPBOYZLT250's Avatar
maybe u guys can help me with this problem......................today I thought my spark plug fouled....so I called my dad to come and get me...well we took out the spark plug on my 92 LT-250r and there is NO spark coming to the spark plug...have any of you guys had this similar problem..if so please help me because we dont know where and how to find out what the problem is..we are thinking either the magneto, coil, or a bad wire in between..do any of you guys know how I could trouble shoot this problem thanks...also if i need parts can you give me a website or phone number?? thx a LOT!!
Old Jun 21, 2004 | 10:55 AM
1987LT250's Avatar
in your clymer manual it has trouble shooting section u can check everything with an ohmeter except the cdi. so process of elimination. gl nice bike
and i also run gearsaver
Old Jun 21, 2004 | 10:57 AM
ok thanks...do you know a site where i can get that clymer manual??? i dont have one( just got the bike) and arent there 2 volumes to it??? do you have both or just one of them?? thanks
Old Jun 21, 2004 | 11:02 AM
  #15
1987LT250's Avatar
i have no idea about 2 volumes i have 2 of same volume one having colorcoded wiring schematic . id go buy one at bike shop like 15 bux but u will need it. sooner or later
Old Jun 21, 2004 | 11:06 AM
  #16
anything else you would recommend me get?? the 87 is like the 92 right?? have you had a problem like this??
Old Jun 21, 2004 | 11:11 AM
  #17
1987LT250's Avatar
not on this one but on the 90 lt250 yes and it will drive ya nuts like any electrical u should have it pinned in an hr . btw if its ur pickup coil on ur stator assebly do not try to chisel screws loose if u strip then u will brak the little ear it connects to off your stator assebly trust me haha
Old Jun 21, 2004 | 11:16 AM
  #18
1987LT250's Avatar
Thu May 27, 2004 7:24 AM
i had to check all mine with ohmeter. everythings checkable except the cdi, so check everything else first.
oh crap your the one without the manual eh ...hahahahah your gonna make me type it all out one fingered .
1987 and later
pickup coil black and black/ white 175-265 ohm
power source coil black/red and black/white 315-475 ohms
lighting coil yellow/red and black/white .5-1.0 ohms
primary resistance coil itself left ground screw on coil to plug wire 0-1 ohms
secondary resistance coil itself right ground screw and black wire 12000-18000 ohms
for accurrate readings components should be atleast 68deg F and be sure to check all your wiring before you start this for broken wires and make sure your black and white wire is grounded good luck again. remind me send u a manual for xmas to save my finger from typing hahahah
1987 lt250
fmf gold series fatty
power core silencer
38mm airstryker
boysen reeds
13tooth front
no toil filter
no lid on airbox
one crazy driver
heres the last one of these i answered ur welcome lol
Old Jun 21, 2004 | 12:52 PM
  #19
gogoquadzilla's Avatar
whoa...put a new plug in then check. too much work to test all that when most of the time its a plug.
Old Jun 21, 2004 | 12:57 PM
  #20
the plug looks new and i dont feel a spark at all...i will get a new plug anyways, and im hoping thats all it is..but i think it MIGHT be something a little more serious...buy i hope you are right gogozilla
