in the front diff. how do you put or change the oil in it. i can't find a drain or anywhere to put oil. or is it seal and you not supposed to put any oil in it. any help would be appreciated.
There is a plug in the bottom to drain and one on the side, right if I rememember correctly to fill. Will check when I get home and let you know exactly.
