04 Suzuki Eiger 400 4x4 hesitates during acceleration
Old Jul 5, 2004 | 08:53 PM
BigLar's Avatar
Default 04 Suzuki Eiger 400 4x4 hesitates during acceleration
Hello,
I have an 04 Eiger. When in neutral, it hesitates and backfires a little when I rev it up. When running, it is really slow to accelerate. I've tried running some fuel system cleaner through it and it still does so. Any ideas?
Thanks in Advance.
BigLar
Old Jul 5, 2004 | 11:12 PM
hondabuster's Avatar
How old is the gas? Bad gas will do this.
Is it hard to start?
If you pull the choke on before doing this, will it get better? Pulling on the choke will richen things up, and if its lean, it should be better with the choke on.
Old Jul 6, 2004 | 12:26 AM
MJE's Avatar
MJE
check out the eiger carb/jetting info...
your mixture screw from the factory is all screwed up supposedly...i tuned mine and it now runs mint.
-Mike
Old Jul 6, 2004 | 01:00 AM
BigLar's Avatar
If I open the choke, it bogs down even further. The gas should be OK. I was able to ride and burn through the gas that I had and I added some fresh 91 octane and the cleaner. Same problem.
It starts fine too.
Thanks.
BigLar
Old Jul 6, 2004 | 01:08 AM
I would have thought it was lean.
Try removing the air box lid for a test drive...this will lean it out, and will run better if its too rich now.
Hows the spark plug look? Air filter clean and reoiled?
Have you tried adjusting the mixture screw?
Old Jul 6, 2004 | 01:48 AM
BigLar's Avatar
The screw did the trick.
Awesome! It idles like a champ now. All I have to do now is convince my wife that I need to go back out and try it again this weekend.
I really appreciate the help.
Thanks to All,
BigLar
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
merryman
Sep 19, 2015 03:15 AM
alzgarvin
Sep 11, 2015 08:53 AM
Sep 1, 2015 11:59 PM
