Raced Yfz-450 WITH MY NOS
#32
FCR gives the most top end power...which I'd assume you'd want since you are on NOS.
How much power will you get?...- How good are you at jetting? You don't have enough motor mods really to see the full benefit of the carb, but go for it if you want.
#36
mine is a 2 wheel drive scrambler my brothe in laws Z has a full pipe, cdi box, 12.5:1 piston, intake cam, fcr carb, cutom intake, and hes a good rider and i still take him by about 4 lengths in the sand.
#37
yah thats pretty nutz.....frickin scrablers gotta fly!.......I remeber discussin that polaris 400 motor with u before, when i didnt know much about it! Gettin air in is a prob, but so is gettin it out, if you dont have a big bore.... Porting i know helps! you will literally about have to run and will benefit most from using NO AIRBOX! and just the huge ProFlow K&N!
I am curious about this also!....i will be running a UM Performance 400EX airbox....ProFlow Filter, and the 400ex Carb Boot....it all fits, and is much larger then the Z400's stock setup is! I have seen this done on several dynoed machines and it proves to be beneficial!
-bLuRRRR27-
SportQuad.com
Project Quads
LTZ-400
-bLuRRRR27-
SportQuad.com
Project Quads
LTZ-400
#38
i talked to arlan lehman (very very knowledgable) of lrd quite a bit down at dunefest, he has been building intakes similar to what we made on our Z for his Z's and both 450's they flow better than any airbox.
