How do you repair small gouges in plastic?
Old Aug 14, 2004 | 10:41 PM
Predator03's Avatar
Default How do you repair small gouges in plastic?
I've got a couple of small gouges in the fenders. Any good way to fix them? Hairdryer? Heat gun? Other ideas?
Come on...someobody's gotta know..
Old Aug 15, 2004 | 12:07 PM
MBrooks420's Avatar
I think you just have to live with them. It's an atv, not a show car, and the only way to make it look nice forever is to throw a tarp over it and never ride it. I would not heat up the plastic as it can make it brittle.
Old Aug 15, 2004 | 05:45 PM
yaaaaaa's Avatar
Well you can start sanding on your fender and that will take the gouge out of it but you will most likely have a low spot, unless you bondo it and then you'll have to repaint it and and you'll have a heck of a deal.
Old Aug 15, 2004 | 05:47 PM
MBrooks420's Avatar
Bondo will crack out as the plastic flexes. Fiberglass resin would work better, but I don't think either would last very long.
Old Aug 15, 2004 | 05:55 PM
Predator03's Avatar
I read on here sometime about a guy using a heat gun....I realize it's an off road vehicle..but it's a surprise for my son, and I'd like for it to look as good as it can for him....
Old Aug 15, 2004 | 09:09 PM
juliuse's Avatar
hey, dont know how much help this would be but i found a plastic welder here i just dot know if it would work for your problem. here is also a how to book to do the welding.
I also found this stuff called fusor plastic repair.
hope this helps. Juliuse
Old Aug 15, 2004 | 09:17 PM
Predator03's Avatar
Thanks guys.....
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
firsttimerider
Sep 26, 2015 01:49 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
