lt 500 sprocket
Old Aug 20, 2004 | 05:36 AM
gnjeff's Avatar
Default lt 500 sprocket
what is a good sprocket combo for dragracing. i will be going to silver lake on labor day.and i need to see if i should try some sprocket comboes. thanks
Old Aug 20, 2004 | 07:51 PM
No2StrokeBs's Avatar
You should be able to run a 13/40 combo and leave in 2nd gear, considering your paddles arent huge. Even so, you may wanna pick up a 12 for the front just in case it wont pull em, either way, you need to be leaving in 2nd gear, so what ever combo it takes for that to happen. Fine tune with the rear sprocket, something like a 13/38, 39 combo. I think you will be fine with a 13/40 setup though.
Old Aug 20, 2004 | 10:30 PM
ZukZilla550's Avatar
14/47 is what I'm using,seem's to work out.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
