Squeaky shocks
Old Aug 23, 2004 | 09:26 PM
DVXer's Avatar
Default Squeaky shocks
I have a 2004 DVX400(I post in here because there are more people that ride z's than DVX's) and all the sudden the front end started squeaking like crazy. I hit the whole front end with WD-40 and it didn't help.There are no grease fittings to lube so that can't be it. I know I can't be the only one with this problem because it happened on my old quad, but not as loud.
Old Aug 23, 2004 | 10:09 PM
mahnster's Avatar
WD-40 eats bushings.
Old Aug 24, 2004 | 12:31 AM
chazekxt's Avatar
mine too
Old Aug 24, 2004 | 01:09 AM
mucky's Avatar
you might have to remove the parts and regrease them
all wd-40 is nothing but kerosine in a can and is not very good
on rubber and bushings
Old Aug 24, 2004 | 03:39 PM
Aaran's Avatar
is this true for all lubricants
Old Aug 24, 2004 | 06:31 PM
DVXer's Avatar
Taking it all apart and regreasing it sounds like a big pain in the butt. I've only had it for like three months and that seems like a lot to do after that short amount of time. There has to be another way. Thanks for the tip on the WD-40.
Old Aug 24, 2004 | 11:44 PM
LT250Rodney's Avatar
Try the shock mounts, my friends Z made all kinds of skwaks and that was it.
Old Aug 26, 2004 | 08:08 AM
DVXer's Avatar
What should I do to them?
Old Aug 26, 2004 | 08:26 AM
Just take the shocks out and lube the mounts. I mean the bolt sleeve not the rubber, that solved my friends squeaks.
Old Aug 26, 2004 | 09:21 AM
rolsmojave3's Avatar
when my mojave did this i removed the shocks and took out the bearings and greased them puppys up real good now it doesn't squeak at all
