more Z400 probs
Old Sep 5, 2004 | 05:54 PM
droz's Avatar
Default more Z400 probs
ok....few weeks ago i had prob with the Z running....wouldn't stay running unless the fuel petcock was in the pri position.....took it apart and cleaned everything out and checked all the lines and everything.....only the fuel petcock had a lil dirt in it......rode fine for about 10 hrs and started acting it....took it up tot he dealer and had them look it over....they seen what i was doing but could find nothing wrong but they also cleaned it......rode for about 10 more hrs and it happened again today....not as bad as b4 but still happening
i now have a cover over the petcock so dust can't get in that way......there is a hose under the seat that runs down to the petcock....is it possible dirt/water is getting in there?
i know under the seat seems to get really dirty/wet from riding......it seems to be the only place it could be entering.
i just need suggestions cuz ive got 40 hrs or so on the bike and have had to clean it 3 times and its becoming a big PITA.
any comments/thoughts are greatly appreciated
also would it be possible to get rid of the new type of petcock and go back to the old style ?
Old Sep 5, 2004 | 05:57 PM
scrambler123's Avatar
does it run fine if you leave it in the prime position?
Old Sep 5, 2004 | 06:59 PM
droz's Avatar
last time it did....this time it kinda runs but starts to hestitate some
conditions i ride in are kinda dusty, some mud, water and grass
Old Sep 5, 2004 | 07:01 PM
we always run ours in the prime position i dont see anything wrong with it.
Old Sep 5, 2004 | 07:19 PM
droz's Avatar
in prime it susposedly bypasses the tubing and stuff to the petcock?
i just wanna get it running and not have to keep cleaning it and stuff and having the dealer tell me there is nothing wrong when something is and its not running right in on position on the petcock
Old Sep 6, 2004 | 11:44 PM
Mars's Avatar
The petcock works with engine vacuum in the "on" position. Prime by-passes the diaphram in the petcock valve. Fuel always flows through the screen on the petcock on/prime/res.
If it will not flow in "on" the diapham is bad or you have a vacuum leak. The vac leak will also cause poor running.
Old Sep 7, 2004 | 12:13 AM
droz's Avatar
i couldn't find a leak so im gonna assume the diaphram is bad......i found a manual petcock for the bike so im gonna order it and get rid of the crappy vacuum system.
right now im just running on prime and using "on" as off
Old Sep 7, 2004 | 11:34 AM
warrior226's Avatar
Just out of curiousity, did you check the breather tube on the fuel cap? Mine got clogged with mud where it plugs into the dash, and ran like yours seems too.
Old Sep 7, 2004 | 03:07 PM
droz's Avatar
yes i did....checked all lines and hoses and everything was clean and clear...even the petcock was completely clean
no leaks to be found n e where and all connections were secure
Old Sep 7, 2004 | 05:18 PM
DaveHoyda's Avatar
i had that sort of problem...never leave it on prime to run tho..it makes your engine run very rich and can cause more problems....after a fair amount of riding...such as your ten hours...the idle screw gets very loose....check that and even tape it if u have to..i had the same sort of problem...but my older bro is ver mechanical and figured it out...
