1977 pe 250 motor in a blaster
Sure, it can be done. To line up the sprockets you'll need to cradle the motor into the frame(you can balance it on a jack) and use a straight edge. This will show you how the motor mounts will need to be fabbed up. I'd consider a larger motor, if you don't have this one just laying around. The PE motor probably isn't much different than a stock Blaster motor. A DT 400 motor would likely fit, and they can be had for relatively cheap. You'd get to stay Yamaha, and the for an old bike the Dt400's rip.
BYC
Sep 25, 2015 02:10 PM
