How
Take the old one of and put a new larger one on? You need a tire that has the same rim diameter. That is the third number in a tire size. Tire od x widthx rim diameter. Ex. if you had 22x11x9 a 25x11x9 would be larger. You can also go wider, but you have to check that you won't rub anything witht he wider tires. Heavier tires also take more power to turn.
