Zilla oils
Old Oct 10, 2004 | 07:33 PM
ZillaRider87's Avatar
Default Zilla oils
what oils do i need to put in besides the trans oil. and how much of it /type / and where does it go for the trans and any others.........
Old Oct 10, 2004 | 11:18 PM
gnjeff's Avatar
Default Zilla oils
be sure to put some in the gass.you will get 20 diferent answers if this post stayes on long you will find everyone runs something different. untill you rebuild your bike and get a new clutch just go to your cycle shop and get the gear oil they recamend. it should take 900 ml or 1 quart. it should be stamped on the case by the black plug on the clutch side.some say synthetics will make your clutch slip. but some say its better for the gears.i would tell you what i run but its a secret.[img]i/expressions/face-icon-small-happy.gif[/img] when i doubt get the manual out!!!!!
Old Oct 11, 2004 | 09:37 AM
ZukZilla550's Avatar
Default Zilla oils
For drag racing I use this combo that seem's to work for me,Golden Spectro and type "F" trans fluid.What the tran's fluid does is help the clutch grab better and help's reduce slippage.
Old Oct 11, 2004 | 10:28 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Zilla oils
There are always a hundred different opinions on oils! Similar question:
http://forums.atvconnection.com/mess...did/421880.cfm
Old Oct 11, 2004 | 07:26 PM
Default Zilla oils
k thanks for the help
1ArmBandit
55
Oct 14, 2015 09:03 PM
Alex G.
Sep 19, 2015 06:34 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
bvolks
Sep 13, 2015 12:57 PM
ScopeZ_
Sep 13, 2015 07:55 AM
