Need Help, Fast Idle After Jetting/Lid Removed
Old Oct 10, 2004 | 04:44 PM
KillingInTheName's Avatar
Default Need Help, Fast Idle After Jetting/Lid Removed
Hey guys, I removed the airbox lid and the silencer from the snorkel and rejetted. I changed out the main jet and the needle/clip then I turned out the pilot screw 3.5 turns. It idles HIGH and hot, choke made it higher, idle screw does nothing really. I've gone all the way up to 5.5 turns out, still very high idle and some popping. Plug base/insulator is tannish, electrode looks a little grey. It ran good at about 4.25 turns out, plug said rich so I changed it to a new one and leaned the pilot down a 1/4 turn and it started this high idle and hasn't stopped, I've been all over the pilot screw. Any suggestions?
-Marc
Old Oct 10, 2004 | 06:28 PM
chazekxt's Avatar
what main did u put back in????
Old Oct 11, 2004 | 01:07 AM
BigSix's Avatar
when i re jetted my z somehow i had accidently loosened where the throttle cable goes into the carb and i didnt notice it....put it back together and started it up and it was idling like nutso high...i was freaked eventually figured it out and tightened it back up...good as new...you might as well give it a check cause my symptoms were just like yours...
Old Oct 11, 2004 | 07:34 PM
Thanks for the replies fellas. I took another look at it and saw that the carb boot going into the engine was cocked to side a bit and was allowing air to get in causing my high idle and lean condition. Running fine now.
Charlie, I put a 146 Dynojet main in.
-Marc
RickyMac
Mar 5, 2016 07:27 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
