z400 flat spots
Old Oct 17, 2004 | 11:47 PM
03hmfz's Avatar
Default z400 flat spots
Rode the old z today. It has a flat spot in the power band on low gears. Kinda like a two stroke. Tried cleaning the carb but it didn't work . Has any one a clue why this is happening.
Old Oct 18, 2004 | 11:58 PM
mucky's Avatar
try cleaning the petcock and a new gas filter if it has one
and change the spark plug if it hasnt been done in a while
Old Oct 19, 2004 | 12:14 AM
bulldogz400's Avatar
A flat spot would not only pertain to some gears and not others. You are experiencing a flat spot at a certain RPM, which would be felt at any gear. My guess is the jetting, and assuming bottom end, the pilot or needle is most likely your problem. What are the current jetting specs?
Old Oct 19, 2004 | 12:28 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
By "flat spot" do you mean that the power doesn't build linearly, or is it a bog? Might be jetting. Play with the fuel mixture screw. Usually it should be around 3.5 turns out.
Old Oct 20, 2004 | 04:06 PM
witti's Avatar
I had a flat/dead spot on my Z aroutd 1/4 throttle after installing a dynojet needle. After trying different clip settings I found it was too rich. I changed back to the stock needle and it runs great.
Old Oct 20, 2004 | 07:22 PM
03hmfz's Avatar
Well, I ruled out the jetting issue because I have been riding it for a year with this same jetting. Could it have anything to do with my valves.
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
