suzuki 230 owners talk here
Old Oct 20, 2004 | 01:40 PM
wannaracelt500's Avatar
Default suzuki 230 owners talk here
any 1 race the 250quadsport wit ur 230 quadsport
Old Oct 20, 2004 | 04:33 PM
MBrooks420's Avatar
The 250 would take the 230 with all other things being equal. 20 more cc's and a better flowing head.
Old Oct 20, 2004 | 05:15 PM
the 250s is a lot uglyer than the 230 and it has that hammerhead seat that is ugly as he!!.
the two motors are almost identical. are the heads interchangeable if so that would be a good bore over for the 230
Old Oct 20, 2004 | 06:59 PM
MBrooks420's Avatar
The heads are different, the cylinders may be the same. Probably not. You can get larger sleeves for the 230 anyways.
Old Oct 20, 2004 | 08:16 PM
superevil's Avatar
as far as the 230s and the 250s is concerned,the top ends are interchangeable,you can bolt a 250s cylinder and head to a 230s bottom end
Old Oct 21, 2004 | 07:14 PM
so that means instead of worrying how far u can go it the 230 head u can slap on the 250s head and get a bigger bore right? or is the piston size gonna be a problem. does both motors fit in either bodies? is the swingarm the same?
Old Oct 21, 2004 | 08:06 PM
MalHombre's Avatar
the 85-86 swingarm is different than the later yrs from 87 on. dunno if there's a diff between the 230 and 250.
where can i get a clutch pack for this thing?
Old Oct 21, 2004 | 10:33 PM
MBrooks420's Avatar
The head never really gets bigger, the cylinder does [img]i/expressions/face-icon-small-smile.gif[/img] Last I knew LA sleeve made a larger bore press in sleeve. I wonder if the headpipe is different. I don't think they list a 230 pipe as fitting the 250. Veserah sells fibers for the 230. You may be able to get slightly stiffer springs.
Old Dec 29, 2004 | 04:12 PM
SPRPRBGT's Avatar
so to recap i take my bottom end of the 230 and buy a 250 cylinder and head and piston slap it together and im good? including the 250 cam and timing chain? can the 230 carb handle the 250?
Old Dec 29, 2004 | 04:55 PM
robnhouston's Avatar
Sounds like a lot of $$$$.
