Z250 Suspension
Old Oct 22, 2004 | 01:46 PM
BrocksZ's Avatar
Default Z250 Suspension
Anyone have any ideas on Z250 suspension? I want to make a little softer and lower if possible. What fits? Does anyone know if any shocks from other quads will fit?
Old Oct 22, 2004 | 05:49 PM
CHEWBACCA's Avatar
you can adjust the shocks to make them softer.. theres a tool in the tool kit thing for it
Old Oct 22, 2004 | 06:31 PM
BrocksZ's Avatar
I've adjusted them all the way to the softest adjustment. The fronts are good to go, but the back is still hard as hell. I have some old stock TRX250R shocks, I'm gonna try and see if those fit.
Old Oct 23, 2004 | 01:05 AM
Shumway's Avatar
I tried to adjust my front using the tool provided in the kit, but i couldnt even turn the dam thing without the tool slipping out of the notches? Any suggestions
Old Oct 24, 2004 | 05:50 PM
z250freak's Avatar
I have to use a big pair of pliers. Works makes shocks for the z, front and rear.
Old Oct 24, 2004 | 07:07 PM
Vinson581's Avatar
jack the quad up and do it. also, or you could use a set of channel locks(what i do)
Old Oct 26, 2004 | 12:27 PM
BrocksZ's Avatar
Well, I tried the 250R shock (rear)....Not even close (looks the same as a Z400). The top and bottom aren't even the same. I might try a Blaster shock. They look pretty close, and I know the Blaster shock is much softer. I was looking at Banshee shocks too, they look about the same as the Blaster one. Does anyone know if Blaster and Banshee rear shocks are compatable? 400ex shocks look like they might fit too, but I don't know anyone that has a 400ex. I also looked at Works site.... holy crap are they expensive. I have Works all around on the 250R, but they came with it. They do ride real nice though. Also, is there any way to adjust the rear shock besides just turning the adjustment screw? Is there something you have to do with the resy?
Old Oct 26, 2004 | 12:57 PM
ZooDadKFX400's Avatar
Not too sure what else will fit, but the rear is not adjustable beyond pre-load.
I have a set of front works that I will be putting up for sale shortly. IF anyone is interested. They have about 5 hours on them and have had covers the whole time.
ZooDad
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
